Does anyone have an idea where to look for the following problem?
A friend of mine allso owns like me a B291 turntable.
His turntable play's exelent. The only problem is that when he want's to play a single
the arm doesn't go to the start position.
So I started with replacing all caps and washed the print with special electronical soap.
Fitted everything together and he runs in 1 time.
Then I swapped the microchip 1.179.353.21 same result. So it's not in there.
In the service manual I can't find anything about which part or ic is responcible for running in to the startposition.
Does anyone of you know where to search?
Meine Revox Geräte:
B790, B215 mk2, B285, B225, B205
B291, B215 mk1, B250, A725, A727, A721. B208
Equipment is upgraded with Jensen, Duelund , Mundorf and Panasonic FC/FR capacitors and Burr Brown opamps.
Revox is poisonous. Once you listen to it, Everything else become abnormal sounding.
