So alot has happend since last, But for those who dont want to use a hour to find prvious posts here is a recap.
I bought a B750 MKII that turned out to be in worse state that expected.
It has been overhauled by a proffesional including new upgrade power supply exchange of faulty transistors etc.
Problem remaning that I would love some inputs on is:
1. the Tone defeat and the level -20dB both have a bad connection issue, it simply seems that they need a good clean. is that possible ? (they loose connection in one channal and if i kind manipulate them a bid it will return.
2. Phono 1 is playing mono meening if input only in left both channels will play (right one the most) if only input in right both will play (right one the most) so same result.
I have added som photos as there is a thing I dont understand with the work arround my technician has made for the Phono 1, he simply connected what I call pin 1 to 4 and 9 to 12
I was of the impression that the AUX board schould work for both Phono 1 and 2 but that seems wrong ?
I thought it was a problem with the input board and found a new one online but that did not change anything!
I hope some can inlighten me Borchee or Ernst56 maybee ;-)
