Please allow me to write in English, my technical German will not be good enough to get my meaning accross:
On the Servo board of the A727 is variable resistor R11, which seems to have the abilty to alter the laser power in two steps, IF the microcontroller sets the control line <LASER GAIN>, (TP1).
However, there is no discussion of this in the service documents.
This is not described in conjunction with the more usual laser curent adjustment on the underside of the player (R13).
Is there any description of this section of the circuitry anywhere, and under what conditions the <LASER GAIN> signal is set high or low?
Thank you.
