Recently I bought an used A764 with RDS and MPX amp board. Tuner works fine. I download the service manual and found that it only has circuit diagram for FM tuner board 1.726.350.81. This .00 to .81 upgrade replaced 18 pin IC TEA 6000 by 20 pin IC TEA 6100. However, the printed circuit board of 1.726.350.81 was still 1.726.320.11, Search the picture of A764 I found that there was a little adaptor board convert 20 pin TEA 6100 to 18 pin TEA 6000.
What is the main purpose for this upgrade? Circuit diagram 5/26 also shown block diagram of TEA 6000 and SAA 1057, but nothing on the adaptor board. Data sheet reveals that TEA6000 feathured 3-stage IF limiter while it was 4-stage symmetrical IF for TEA6100. Since .81 revision still use the same PC board it would be possible to do this upgrade by replacing components.
Anyone has gone through this process before? Do we have to re-align the tuner after the components change?
By the way, which components are responsible for 50us/75us change of 1.726.352?
Thank you for your input.
Best Regards,
Yeun-Jung Wu
