When having a listen to it I found out that there is a large difference in the volume. The left channel seems to produce less sound then the right channel. When turning the balance button you can more or less solve the problem but you still hear the difference between the left and right channel.
The heads are in good order. The are very clean and the rollers are also in good condition.
I changed the playback amplifiers from possition on the switchboard and the problem moved as well. So I guess that one board is not working correctly.
What can I do with this? Do I have to replace the transistors on the board or can this problem be solved in another way?
Or do I have to look elsewhere? Is there another way to solve this problem?
I'm also looking for the amplifier board. Does anyone have a pair for me?
We can talk about the price.
I recently started with revox (the A77 is my first one).
Many thanks for your advice.
Steve
Belgium
