My B261 tuner has a function problem. After it developed a 100 Hz background noise, I replaced all electrolytical capacitors in the power supply with high quality Elna. The noise disappeared and the overall sonic performance improved. However, while I was checking the +33V voltage on the pin 1, the probe slipped and accidentally made a short circuit between pin 1 (+33V) and pin 2 (-22V). So, it was my fault. As the consequence, the tuner shows the following strange logical behaviour:
- the tuner is always on and so are the display lamps
- when I press POWER it does not turn off
- station memory is erased and it is impossible to store stations anymore
- after a few minutes the tuner does not react to any button anymore
Here is the good side:
- tuner is sonically fine as it was
- stereo, mono and muting work
- automatic and manual scanning works
- frequency indication works
- typing frequency by numbers works too.
After this happened, I checked the power supply again. All transistors, diodes and zener diodes are OK. Output voltages on all pins are OK, as well.
I think the problem is on the microprocessor PCB, somewhere between the SAA1061-3 and ER1400. But, since I have no experience in logical circuits I don’t know how to test them. I think the key for understainding the fault is the fact that pins 1 and 2 have been shortcircuited.
Does anyone have any suggestions or advice which part has gone wrong? Thank you in advance.
