Fernbedienung für H2
    welche FB funktioniert am H2 CD-Player?
    Geht hier nur die H208 oder gibts da Alternativen?
    Über ein paar Hinweise oder Erfahrungen würde ich mich freuen!
    Vielen Dank.
    Fred
    AW: Fernbedienung für H2
    Hallo Fred,
    H8, H210, SRC2000 (mkI, mkII), M207, wahrscheinlich auch M208 und möglicherweise auch eine Universale.
      Hello,
      You might try some Marantz remote controls.
      My H6 tuner responds to a "universal" remote control when set to send Marantz protocols.
        Hello Steerpike,
        Zitat von steerpike Beitrag anzeigen
        ... "universal" remote control when set to send Marantz protocols.
        just curious...have you try it, set to Philips protocols, with H11?
          Zitat von borchee Beitrag anzeigen
          Hello Steerpike,
          The H11 has no IR receiver, it only works by getting a cable command from the H5 amplifier, and I do not have the H5.
          The H1 is different - it uses the old Nokia/ITT IR commands, so works with B208, B201, B205.
          I'm thinking that the H11 also uses these same Nokia/ITT commands via cable, and the H5 does translation from Philips to Nokia protocol.
          (The H5 doesn't know which cassette deck is plugged in, it could be H1 or H11, so the H5 must be sending the same protocol codes to both)
            How odd?!...didnt know H11 lacks the IR receiver.
            I'm aware of that...of H9 as well.
            Sounds logical to me. What about H11 with B202 or B203?
              The H11 on a B200 or B203 is an interesting experiment! I have not tried it.
              The socket on the H11 is a 6-pin DIN, so B202 will not plug in without modification.
              Since the H11 (and C115) is really a Philips FC60, there is probably an IR input pin on the microprocessor, that works with Philips RC5 data, but none of the diagrams I have show the MPU pin functions.
                As far as I could figure it out, the Marantz SD72 is basically the same machine...with built in IR receiver.
                  vielen Dank für die Anregeungen....
                  wobei sich für mich die Frage stellt: Geht das überhaupt mit der FB und dem H2 als Einzelgerät aus der H-Serie, ohne weiteres Gerät aus der H-Serie (H5,H6...)...???
                  Fred
                    ...The socket on the H11 is a 6-pin DIN, so B202 will not plug in without modification...
                    Hi,
                    the B202 has an parallel output (each function has one wire).
                    So there is nothing to do with an B202 and H11(H1).
                    Driving the H11(H1) from an B200 or B203 should work.
                      ...ginge eigentlich die B208 auch für den H2?...die B208 und H208 sehen sehr ähnlich aus....
                        Hallo Fred,
                        den H2 kannst du aleinstehend fernbedienen, so wie es steerpike mit seinem H6 macht.
                        Von Revox kommt noch die H208DSR in Frage.
                        Keine FB der B-Serie kann den H2 steuern, da anderer Code...B2xx mit ITT Nokia und H2 mit Philips RC5.
                        Ich rate dir zu einer universalen...soltte mit RC5 nicht schwierig sein...gleich bei Philips nachsehen oder Marantz (war in den achtzigern im Philips Konzern) oder halt eine x-bellibige...dürfte auch billiger werden, oder auch nicht, je nach deinen Anforderungen.
                          Hallo Borut,
                          vielen Dank nochmals für deine Hinweise...
                          sollte ich keine günstige H208 bekommen, werde ich mich nach einer universellen RC-5 FB umsehen....die gibt es schon ab 10 Euronen so wie ich sehe....
                          Fred
                            Hallo nochmal,
                            weiß zufällig jemand wo man die Bedienungsanleitung oder Service Manual für die Fernbedienung H208 bekommt?
                            Vielen Dank.
                            Fred
                              Reicht dir das?
