Greetings from Spain.
The thing is that I own a B225 cd player and after cleaning up the interior of the device using an air blower the player powers on automatically when plugged in, the cd tray opens and closes with no issues but the command keys do not respond when pressed. Also, no information appears on the front screen and I cannot power off the device with the "Power" key -the player has to be plugged off.
I have to remark that the player was working fine before cleaning up.
Note: the command key contacts are pretty clean, as the connector pins of every PCB board.
Would you help me out?
Thank you in advance.
Daniel
