I am a ReVox lover (I have a B225 and a B780).
My cdplayer B225 works fine but sometimes has a small problem, especially when it's cold (first use in the day).
When I press 'play' after inserting a CD, the CD spins slowly for 1/2 seconds producing a bad metallic sound (it seems an abnormal friction), then stops. Then spins again for 1/2 seconds in same way, then stops again.
It does this sequence for three-four times, then stops definitively and display shows all '0'. The TOC isn't recognized.
If I press play again same thing happens, start procedure fails again.
The only sure way to eliminate the problem is turn off the player with 'Power' key and turn it on again.
But if I make this procedure *before* to press play, the cd always start in correct way. No stops, no metallic sound...runs freely and TOC is recognized.
I could solve this problem in this way (every time that i want to play a CD I must press power 'on' and 'off' twice), but I hope that someone could help me to solve this problem in a correct way.
Laser lens were cleaned (Some month ago I had some problem in recognizing tracks, but after cleaning all returned OK).
Thanks
Francesco
