I have a B261. A years ago i replaced all caps on the power supply board and audio board. The B261 worked fine afterwards for a few years. Becuase of circumstances the B261 was stored awsy for over 1 year. When I reconnected everything memory seems intact, preset names and frequency are still the same as 1 year ago. But the sound is highly distorded. Especially on louder stations. The distortion is on both channels, but worse on the right channel. The problem is present on fixed, variable and headphoneoutput. What is the most common cause for this kind of issue?
Do i need change the caps on the other boards or do i need to change the potentiometers,...
Thank you for your replies,
