It's been almost a year since I fully restored my last B251. I restored 3 total yet but I must say the last one was the holygrail of all. Don't get me wrong, it is still functioning very well and this the one that is sounding the best of all. BUT!
I don't know if Milan is still around on this forum but I 100% agree with something Milan Milosevic wrote into another forum in 2022 in regards of the B251.
Here is his statement:
"Properly designed switching power supplies have lower noise and lower ripple, because they operate at higher frequencies. The audio industry welcomed SMPS because it allowed for the design of high gain stages with very low noise, as in Sony TA-F6. They also provide excellent transient response, as in Revox B251 (2μS rise time). However, they also exhibit some "shortness of breath", and they cannot deliver the same bass punch as their linear counterparts: these amplifiers will always sound a bit "light", while they excel in ranges above. In general, SMPS are best suited for constant loads.
All other cons of SMPS, such as noise and EMF pollution going back to the mains, are due to cheap and poorly designed circuits."
It is not my nature to give-up easily and wondering if this "problem" can be fixed, improved or just there is nothing we can do about it.
If I'm comparing with other amplifier designs, I'm often seeing large reservoir capacitors (thousands of Uf) on the voltage rail feeding the amplifier output stage. However, for the B251, the only candidates for this task would be the C113, C113, C312 and C313 of value of 220uf only. I'm wondering if increasing the capacitance to ~ 1000uF would be beneficial at all or maybe detrimental because to current surge added onto the power supply to "fill" those?
Let me know what you think!
Thank you!
Charles
Regards,
